Found a X-mas present *Pic*
badingle
127
Portage, Michigan
:banana:
A 3.5" wheel is refered to a "skinny" and having such a small width wheel allows you to run a 165R15 or similar drag tire up front. This reduces weight and rolling resistance which will both help improve straigh line acceleration... its not so good as you can imagine for the corners. Also the term "big and littles" refers to running a small width "skinny" wheel up front and a wider wheel (15X10 for example) out back. You can NOT run these on a cobra unless you put longer wheel studs in and run spacers. Bogart makes a direct fit wheel to clear the cobra brakes, but you must also run longer wheel studs to clear the caliper. Welcome to the site, but just understand that this is a good group of people and any post like the one above is just there to laugh at, don't take it to mean anything... its all in good fun.
So, what does your car run and what's the combo? You should do an introduction thread and tell us about you and the car. There are some very knowledgable and friendly people here.
