Four link suspension question
  • Thread starter Thread starter iamblackjack
  • Start date Start date Oct 7, 2004
I
iamblackjack
12
  • Oct 7, 2004
I got my front suspension from Scott's Hotrods and it's awsome. Top notch quality. They said that they could build me a rear four link as well, but I didn't feel that they understood the complexity of my problem. I had to send some parts back to them, so I packed some pictures and measuments aswell of the rear sub frame.
Here's what I got: I've built a new subframe from the front seat back. It follows the stock profile for the most part, but it is only 32 3/8" wide (all the way back). I planned on keeping a back seat and I didn't want to "back half" the car. The problem is that the upper links will have to be quite a bit shorter than the lower ones. I'd drawn up some designs my self and found that the pinion angle will only be change about 1-2 degrees when the suspension moves up or down 2". I showed my plans to a local race car builder and he said that they wouldn't work. He tried to sway me towards ladder bars (I plan on driving this car 98% on the street and I don't think that I want ladder bars ) I didn't see an engineering degree hanging on the wall either, so who knows.
Now, I'm no engineer, but I think that I've got a pretty good idea how things "work". I've searched the web alot trying to find some info on this subject, but I keep coming up with dirt track and race car designs.
Can any one help me out or point me in the right dirrection? I can e-mail pictures and scans of the measuments and designs.
Thanks,
Kirk.
66P51GT
721
Cerritos, CA
Oct 8, 2004
  • Oct 8, 2004
This sounds like a job for http://www.corner-carvers.com/
rbohm
6,698
550
204
tucson,az
Oct 8, 2004
  • Oct 8, 2004
if the links are not equal, the suspension has a tendency to bind when in motion. the pinion angle may not change too much, but that is without the driveshaft in place, and that is where the bind may occur. either way you will need a panhard bar to locate the rear axle lateraly.
I
iamblackjack
12
  • Oct 8, 2004
I went to that web site and read alot of the threads. There was some good info. I tried to register, but some reason it was turned off by the administrator at the time. I'll try again later. I'd like to post my question dirrectly.
BTW. I was wanting to use a diagonal bar (I think that they call this a "Z" link). I didn't want to use a panhard bar or watts link because I was affraid that it would interfear with the exhaust (I want to run 2.5" or 3" over the rear end).
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
