- Jan 12, 2006
- 1
- 0
- 0
How much faster is a fox body 5.0 than a 94-95 5.0 when stock. Is a stock, say, hatchback GT as fast as a 94-95 Cobra stock? Thanks
Copper_5.0 said:How much faster is a fox body 5.0 than a 94-95 5.0 when stock. Is a stock, say, hatchback GT as fast as a 94-95 Cobra stock? Thanks
SeventyMach1 said:Well .... what are the hp ratings for the Fox's? I know for the 94-95 GT, it's 215. And 240 for the Cobra's. Plus, there's a few modernized things that count for a little bit of power (i.e. electric fan). The weight isn't that much of a difference (at least between a hatchback GT and a GTS).
nmcgrawj said:Cause im sure the 94-95 GTS models would run right along with the fox's.
5spd GT said:My foxbody weighed (full weight) 3180lbs when it was "factory". That had the smog delete (only weight reduction per say).
Weighed friends 95 gt (stock as stock can be)...it weighed 3360lbs with more gas in his tank than I had.
Friends 00 GT weighed 3337lbs with the same amount of gas.
nmcgrawj said:So the GT fox body would be even closer to the sn95's correct? I've always wondered about that...seems like people get different numbers than "quote" on different sites.
5spd GT said:Drivers effect a lot...and the stock gears make differences as well...transmission as well.
