I used a fox body radiator in my 66, send pics later. I did cut the bulge part of the support, wasn't necessary though. Just makesa for a better fit. I'm running a permacool electric fan 16in. puller and it fits great. was using the plastic type from kragen and it was close to the water pump snout. Oh, I did run into an issure at the bottom of the radiator. The fender aprons taper in on the way down, and are a bit tight for the radiator, actually too tight for it to fit flush. I took a hammer and massaged to bottom corners a bit. About 1/2 inch total. It slips in fine. 1 last thing, I had to trim the top of the radiator support where it folds towards the driver seat so that I could remove the radiator cap. For the water pump, I used a 70 Stang with the exit on the drivers side, if you use a fox body pump you need the pulley setup too cause its reverse rotation. I did use an old style and turned the curved hose towards the balancer and used an exhause fitting from checkers to reduce the 1.75? hose to 1.5? hose and put a smaller fleax hose off that and ran it to the radiator. Sorry for the run-ons, I'm in Hawaii, its late, and hirlfriend is calling. Good luck, oh, it does stay cooler.
