Fox Convertible owners, got a ?
I am pretty sure that mine is glued to the window. I'll have to check when I get home from work but I am pretty sure you can't pull the fabric away from the lower glass like that.
Yea, it is supposed to be glued to the window. Mine had a small part that came unglued and was leaking into my trunk. I used automotive Goop to stick it back on. Just make sure that you clean off the glass before you use it. It will make the glue more permanent.
