Okay
is there anything wiring wise that the
-Reverse Lights
-Turning Signals
-Rear Defroster
share in common?
Why?
-When i first got the car all three worked in unison and all three would not work in unison. meaning if 1 worked all worked 1 one did not work none worked
Finally they have officially stopped being intermittent and now completely do not work...
I have a couple wiring diagrams but can't seem to find anthing in common with the 3 (i suck at wiring)
Little back round info to help you guys maybe recognize a source of the problem
I would have to shake the turn signal lever for a bit to get it to work, same with the rear defroster button id have to keep pushing it
Somtimes if i got the rear defroster on (at this point i knew turn signal would go on) as soon as i turn the signals the rear defroster would make a click noise and turn off... and after toying with it i could get it to stay on
Also when the signal was on... it blinked painfully SLOW
To correct this i have
-replaced every fuse
-new Flasher for both hazard and signals
-hunted down wires for countless hours resulting in me getting NO WHERE lol
I have heard possibly the multifunction switch
but i have a diagram that i been using and it doesn't show the defroster or reverse lights on it.
-Reverse Lights
-Turning Signals
-Rear Defroster
share in common?
Why?
