Fox hood latches
tuhockey11
81
PA
I recently aquired a 92 GT, but previously I have owned a 90 GT and 91 Notchback. On both of those cars the hoods ended up flying up on the highway. i have also heard of others having this happen to them. Is there anything I can do to prevent this from happening again, it causes major damage and just plain sucks. Also, hood pins are out of the question, i cant stand them.
Just make sure you latch it good and make sure the safety latch works. I always give mine a good yank after I close it to make sure it's latched. Sometimes it latches, but pops back up. You want to make sure it's greased/lubed every now and then too to keep from sticking. Other than that, hood pins are the only other option. There's always the nice low profile keyed hood pins. They're kind of a reverse pin thing...
The safety catch is a huge help. Comes standard on all cars. Some people get rid of them to ditch weight I think. I down know how much faster your car would be with 1 ounce missing!! hehe
Mine does hav the safety latch and it works, so i guess Im ok...The other two cars I had were modded before I got them, so i guess someone messed around with them. Leanred my lesson and only buy bone stock cars now:D
If you don't want hood pins I guess you could always fabricate some type of reverse pin system using a plastic coated wire rope/cable with enough slack that you could unhook it after you pop the hood. Bolt the cable to the hood side part of the latch and the pin to somewhere on the radiator support. Just a thought. Are you using aftermarket hoods or stock, never heard of a properly functioning stock hood flying off.
