Fox Issues
  • Thread starter Thread starter MYTURBO
  • Start date Start date Sep 4, 2016
  • 3
1 of 3 Next Last
MYTURBO
50
Wichita Kansas
Sep 4, 2016
  • Sep 4, 2016
Alright, I've been having a few issues RECENTLY..
Car runs super rich! Throws Lean codes. Sputtering very romp...romp...etc idle (not surge)
Pulled the intake as it seemed to be leaking causing a vacuum leak. Figured that was my rich, lean code issues.
Got it all back together , installed a msd 6al2 while I was at it.
Got it all back together. Still have the same issues! And I noticed when i run codes it shows **6cyl** now . Makes no sense!
Also cylinder balance test comes back just fine..
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 5, 2016
  • Sep 5, 2016
What are the actual code numbers?
The 6cyl thing is common....ignore it
Sent from my big ass iPhone 6 using Tapatalk
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 5, 2016
  • Sep 5, 2016
disconnect the MSD..check all vacuum lines and that all bolts are torqued down. As Mike said, what are the actual codes.. Could be a lot of things. Do you have any smog equipment disconnecct?
MYTURBO
50
Wichita Kansas
Sep 11, 2016
  • Sep 11, 2016
Sorry guys, been trying so many things. And nothing has fixed it. Tried multiple ECU's.
Now the cylinder# is just blank, no number at all.
Checked pump out, injectors, fuel pressure. Made sure no injectors are leaking and the fpr isn't leaking or bleeding off, pulled engine harness, went through all the wiring, tested from end to end. All good. Tried 3 mafs, new Distributor etc.
No emissions are on the car, egr is plugged in with no vac line, been this way over a year without issue.
Only thing I get is lean codes, and emissions but I always had ems codes, but the car runs rich! Idle and low rpm,cruise issues
Changed the oil 6 days ago. Smells of gas already. Only drive the car 30-40miles a week.
I'm just at a loss, getting really close to going carbed lol
Reactions: Davedacarpainter
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Sep 11, 2016
  • Sep 11, 2016
You need to take the msd off first to verify you didn't mess something up wiring it
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 11, 2016
  • Sep 11, 2016
So what are actual codes?
MYTURBO
50
Wichita Kansas
Sep 11, 2016
  • Sep 11, 2016
It was the same issues before hand, unhooking the msd makes no change.
Codes are emissions and lean (02s) but the car isn't lean. Rich by a long shot!
Currently have the eec harness out on my kitchen floor, 2 pinouts I can't find a end connection to.
Searching as we speak for what these wires are for.
90sickfox
Wasn't a pretty sight...and I've got big hands
Mar 2, 2015
6,953
5,831
213
Sep 11, 2016
  • Sep 11, 2016
I chased my tail on an issue like this. My car idled bad....the fumes would run people out of my shop and got lean codes.
The problem ended up being my o2 sensor harness was shredded on my k member. The computer thought it was lean so it dumped fuel.
MYTURBO
50
Wichita Kansas
Sep 11, 2016
  • Sep 11, 2016
I messed with the o2 harness about 6mos ago when I had issues, got it fixed. So I didn't really look into it this time.
I know right now 2 wires are dead in the eec harness.. can't find an 89 pinouts to figure it out.
90sickfox
Mar 2, 2015
6,953
5,831
213
Sep 11, 2016
#10
  • Sep 11, 2016
  • #10
What pins are they ? I can take a look in the am in my service manual. Sure someone here knows them by heart.
MYTURBO
50
Wichita Kansas
Sep 11, 2016
#11
  • Sep 11, 2016
  • #11
Found a diagram, all fixed but 1, pin 4 which goes to the tfi module connector.
I see in the diagram their is an inline resistor, guessing that's the issue
MYTURBO
50
Wichita Kansas
Sep 12, 2016
#12
  • Sep 12, 2016
  • #12
Could anyone tell me what the left capacitor is for ? Noticed all my ECU's are burning them out
MYTURBO
50
Wichita Kansas
Sep 12, 2016
#13
  • Sep 12, 2016
  • #13
So the ecu harness checks out, I didn't know a few wires had to be tested at a certain resistance, due to the resistor in the wire.
Also pulled the 02 harness and tested for shorts, and connection. It's perfect
Engine harness I did last week.
So with that being said, Who's got some ideas ? Could an 02 throw a lean code, but be bad and cause rich running. And blowing the same capacitor in the ecu ?
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Sep 13, 2016
#14
  • Sep 13, 2016
  • #14
Shouldn't this be in tech where @jrichker can help too? @MYTURBO I think posting all of the engine codes would be best so jrichker and others can see all the cards on the table and help you out the best that we can.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#15
  • Sep 13, 2016
  • #15
As I said earlier, only codes are emissions (which don't matter) always had them with no issues, and Lean Codes. But car runs rich.
No other Codes
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#16
  • Sep 13, 2016
  • #16
Could, o2 sensors be bad , throw a lean code and cause these issues ?
I haven't tried new ones, as i don't want to just throw parts at it in hopes all is going to be better.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 13, 2016
#17
  • Sep 13, 2016
  • #17
What are your mods. Sounds like your car is running lean to me, not rich?
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 13, 2016
#18
  • Sep 13, 2016
  • #18
Only situations can see where car runs rich but throws lean codes are if the o2 sensors themselves are bad. They are telling the ecu to fatten up the mixture and are not responding.
What year is this car? It's not a MAF conversion or 2.3L conversion is it?
Actual code numbers would be a big help vs description.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#19
  • Sep 13, 2016
  • #19
It runs rich for sure. Raw fuel.
It's a built alum headed 306.
Tried different injectors,fp, fpr, mafs, tps,iac, ECU's. Messed with every harness. All have tested good.
Figured the lean code but running rich may also be vacuum leak, pulled intake and re sealed everything.
Issue is still present
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#20
  • Sep 13, 2016
  • #20
87 2.3 car. 89 maf harnesses a91 etc.. the car ran fine for a long time. For about a month it has done this.
  • 3
1 of 3 Next Last
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
