Fox Issues
  • Thread starter Thread starter MYTURBO
  • Start date Start date Sep 4, 2016
  • 3
First Prev 2 of 3 Next Last
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#21
  • Sep 13, 2016
  • #21
I had just figured it was a short somewhere, due to ecu caps being bad (leg melted off and leaking) I know caps going bad can be normal. But the melted leg worried me.
I tried another ecu and had the same issue, bad cap. But it may have been bad already. Ecu sat in a box as a spare for years. No idea what it's condition was before hand.
I'm just not the kinda person to dump money into the Unknown without thorough inspection, exp on a 29yo car
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#22
  • Sep 13, 2016
  • #22
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 13, 2016
#23
  • Sep 13, 2016
  • #23
What year car?
Mass Air or Speed density?
As mentioned, please post the numeric codes.
I have 5.0 Fox Mustang specific code definitions and fixes.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#24
  • Sep 13, 2016
  • #24
It has been a bit , code 41 and another 02 code. Don't remember the other code honestly. It was an 02 code. IF I remember correctly both were Rh o2 codes
Could be just a bad o2, But honestly got worried once I noticed I had bad ecu caps. I know leaking is normal, but the leg to one was gone, which lead me to believe I had a wiring issue.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#25
  • Sep 13, 2016
  • #25
I originally bought the car as someone's failed 302 swap, had an SD harness all hacked up with frayed and melted wires.
Car is an 87 factory 2.3. now is a v8 maf car
So I scraped it all. Got the correct Maf harness that plugs into my dash harness. Etc. Car ran great for awhile until recently
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 13, 2016
#26
  • Sep 13, 2016
  • #26
A9L computer. What O2 sensor harness are you running? Where is the jumper on the O2 side pinned to?
If this jumper is incorrect, it tends to cause computer issues such as voltage on the SIGRTN trace (Pin 46) causing similar issues to what you describe. Best way to check is to pull the EEC out, put a DMM on pin 46 and crank the engine. If you have voltage here, you need to move the jumper on the O2 harness.
This particular aspect is critical on 2.3L conversions. The O2 harness needs to come from a specific year range, and match the transmission (Computer type)
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#27
  • Sep 13, 2016
  • #27
Jumper is correct checked it
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#28
  • Sep 13, 2016
  • #28
Also tried moving the jumper and using an auto ecu. Same issues
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 13, 2016
#29
  • Sep 13, 2016
  • #29
MYTURBO said:
It runs rich for sure. Raw fuel.
Is it raw fuel though, or just a really stinking exhaust smell. Contrary to popular belief, a car that runs excessively lean actually give off a stronger exhaust sent and higher emmisions than one that's running rich. And your O2's and surging running condition are backing that theory. Let me guess....it bucks at lower RPM and randomly backfires through the intake too?
I chased my tail for the longest time with the same issue, believing the same as you. Turned out I was way off. Idle A/F was almost 20:1. I'm surprised it even ran.
If I were you, I'd invest in a decent wide band sensor before putting all your resources into leaning the car out. You can pick up a nice sensor gauge combo for under $200.
I'm running this one on my car and it works flawlessly.
http://www.plxdevices.com/Wideband-O2-Touch-Screen-Multi-Guage-p/897346002719.htm
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#30
  • Sep 13, 2016
  • #30
Bucks yes, no backfires. Thru intake ,gets enough fuel to ignite it in the muffler's.
Again, this issue recently started happening.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#31
  • Sep 13, 2016
  • #31
Exhaust exits are black! Like they would be if rich.
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 13, 2016
#32
  • Sep 13, 2016
  • #32
Not to be a broken record, but could you please erase all current codes, and then rerun and post actual numbers?
You mentioned both codes pointed to RH o2 sensor, but are you sure? If the codes point to both sensors, my recommendation would be slightly different than if it pointed to the sensor on one side.
For instance, if you got lean codes on only one side, I'd suggest swapping the o2 sensors and seeing of the code numbers change to follow the sensor. However, if both sides read lean, that won't work for obvious reasons.
Nobody likes throwing wasted money at a problem, but it's important to get a clear picture of what the problem is when trying to diagnose over the net. We can't see what the car is doing
Sent from my big ass iPhone 6 using Tapatalk
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#33
  • Sep 13, 2016
  • #33
Yes I am positive it is the Rh only, I have cleared codes many times, swapped injectors etc. It is in fact rich. But reading lean. I replaced the lh o2 awhile back due to wires being frayed. No idea how old the Rh is.
I have an o2 I will hopefully get on the car today, but I still have to install the harnesses, and a few other things.
Is the burn capacitor leg just a coincidence everyone think ? All harnesses have checked out.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#34
  • Sep 13, 2016
  • #34
Now that it's all back together, their is a mess of codes!
Koer: 41,4,66,42,14,65,32,3
Koeo: 85,95
balance test: 90 (pass)
Pulling ecu to check it out again now...
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#35
  • Sep 13, 2016
  • #35
Ecu is good, no bad caps or burnt circuits.
I don't even know
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Sep 13, 2016
#36
  • Sep 13, 2016
  • #36
I don't even know
You need the all wise @jrichker @Mustang5L5 or one of the many smart guys on here.
At least you're making some kind of head way....the computer is still good.
Running rich can sometimes trigger a lean code from the unburnt oxygen in the fuel.
I hope you get this figured out.
MYTURBO
50
Wichita Kansas
Sep 13, 2016
#37
  • Sep 13, 2016
  • #37
At this point I'm seriously considering doing a carbed setup.
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 14, 2016
#38
  • Sep 14, 2016
  • #38
Koeo: 85,95
Fox Mustang engine codes are all 2 digit.
Can you redo the KOER codes as 2 digit codes? I can take a guess, but if you can redo them it would help.
I would guess 41, 46, 64, 21, 46, 53, 23.
If correct, it tells us your IAT, ECT are not reading correctly, and the TPS sensor voltage is set way too high at idle.
Code 41 is system Lean RH
Code 46 is air injection (smog pump) not working
Code 64 is Intake Air Temp sensor signal low
Code 21 is Engine Coolant Temp sensor out of range (if you run the codes with cold engine, you get this)
Code 53 is TPS voltage too high
Code 23 I TPS voltage too high.
Check to see that your TPS voltage is set to 0.6 - 1.1 volts at idle. You don't need to chase a 0.99999v number. It just needs to be within that 0.6-1.1 range.
MYTURBO
50
Wichita Kansas
Sep 14, 2016
#39
  • Sep 14, 2016
  • #39
I redid the test 4 times. Even said f it and drove the car. Then ran the test again.
The single digits had a 0 infringe of them. Struck me as odd, but figured maybe their is a few codes that are rare, I guess.
MYTURBO
50
Wichita Kansas
Sep 14, 2016
#40
  • Sep 14, 2016
  • #40
Tps is .98v
No way I have all bad sensors now lol . Idk what is going on with the car!
  • 3
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
