FOX TB CONVERSION EGR HELP
NO_RICE
405
Tucson, AZ
I am doing the fox TB conversion, and I want to run the cooling lines through the EGR plate, the problem is I can't remember where the lines connected to on my fox, does anyone have pictures of how the lines connect?
The cooling lines connect to the water pipe for the heater core that runs under the TB on the passenger side. The only problem is that SN95 5.0's don't have the trees on that pipe for those lines.
You would have to run that pipe assembly from a Fox if you wanted those. I have one of those assemblies that I'm not using if you're interested.
I would plug them, but the emissions people are real ball busters. They failed me for a missing vaccum line last time, even though I passed the sniffer test.
illwood - Do you have pictures? How much would you want for them?
