Engine Foxbody powered F100 issues...
Keep in mind there are two checklists, the 'cranks but no start checklist' and the 'surging idle checklist '.
Also when an engine has problems with running ruff then no starting I pull the plugs and clean/replace them, copper plugs are still pretty inexpensive. Then I clean the contacts on the rotor and distributor cap, then see if you get spark starting at the coil, then coil wire, the plug wires. I also make sure nothing has changed in the timing, several times I have found a distributor loose and has moved causing idle, miss fire and no start conditions.
Thanks for the response...I do not have the msd box on this. I will the check the spark to the plugs again but 2 days ago it started and ran roughly for about 5 secs then returning to the no-start condition. I have also pulled the spout several times over the last few days and it has never started that way. I will review the checklist again and see if I've missed something. Thanks again!
Also, I just checked again and I do have spark to the plugs but it still won't start with starting fluid...
Thanks, yes I'm aware of both checklists. I have cleaned the plugs, rotor and the contacts inside the cap. I also have a couple of extra caps which I have interchanged with no change in the situation. As for the timing, I had tried a completely new distributor but it was no different, so I put my old one back in. I made certain that the #1 plug was TDC point the TFI to a same position it had when it was running good, so it could start and run....but it hasn't...argh!
@randyr
It’s Decision Tree time:
No spark = go to step #1 & 2.
Good spark - what is a good spark can be a subjective judgment. If you have any doubts, borrow a known good coil from another pre 1996 Ford.
If you do have good spark = go to step # 3
Engine fires off and then dies = go to step # 4
Make sure that you have fuel pressure when the engine fires off. Leave the fuel pressure gauge connected while testing so that you can observe what the fuel pressure is doing.
Fuel pressure OK while cranking
Go to step # 5
Be sure to use a noid light to see if the injectors are pulsing. Use the most accessible fuel injector connector for the noid test.
Noid light pulses and fuel pressure is good.
Go to step #6
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts briefly then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t, then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachments\68357
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
attachments\610738
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Reactions: General karthief
@randyr
Go to step # 5
Go to step #6
D.) Coil
Wiring Diagrams:
B.) Distributor cap
C.) Rotor
Two reasons:
attachments\68357
attachments\610738
Thanks! I will start on this list again tomorrow and see if I missed anything...I must have! FYI the Ford Racing harness doesn't have the 10 pin "salt & pepper shakers" but most everything else is there. Thanks again for your persistence in helping me find the problem! I really appreciate it!!! Happy Thanksgiving!!
I like it when someone is persistent and not all 'I'm gonna burn this thing'! It is usually something ya missed or overlooked.
BTW, how bout some pics of this box?
yeah, I gotta persist....love the truck too much to want to burn it....but tossing the engine out if not out of the question! LOL! Here's a couple of pics. It's the same truck in my avatar.
Ok, gents, here's an update on my never-ending quest to make this thing run again...I started by re-stabbing the distributor just to make sure for the 4th time that it wasn't 180 degrees off...lol...
From there, I have good spark at the coil & distributor. I used an inline spark plug tester light and get good sparks from everywhere except the #1. I get no spark on #1 at the distributor end of the wire or at the plug end. All other plugs have good spark. I have no idea why #1 is dead. I replaced the spark plug in case it was broken or shorting out but still no spark on #1
In spite of that, per the instructions, I moved on to step #3 because I figured it should still run even if #1 isn't working.
Step #3, I followed the instructions of step 3 and it wouldn't start, however, 2 days ago it randomly started on the first try and ran poorly for about 5 seconds, then died again. Back to No-start. Using the starter fluid resulted in no indication it was trying to start. The fuel pump primes properly and I leave the fuel pressure gauge in the schrader valve. It shows 34psi when cranking with vacuum hose connected and 42psi when vacuum is plugged.
Step 4 doesn't apply since i have fuel pressure...on to step 5
Step 5....using a noid light, I determined the fuel injectors are firing.
Step 6...I cleaned and inspected the IAB and nothing changed. I tried pressing the throttle down 1/4 and still nothing.
I also ran a compression test on the engine. The numbers are really low but I think they've been low for a long time and it ran good. Supposedly the engine now has around 120k miles on it. I replaced the timing chain 20K miles ago when I had a leaking timing cover. I think it's highly unlikely that the timing chain failed after 20k miles plus the engine has started and ran for few seconds several times since this condition started.
I also installed new capacitors in the ecu, as I stated in an earlier post. Other things I've tried included a new distributor, new TFI module, different coil, cleaned and tested the EGR valve, checked for vacuum leaks, replaced gaskets on upper plenum, throttle body, IAB, new dist cap & rotor.
I'm all ears....
I apologize for reviving an older thread but, my curiosity got the best of me; did you ever figure out what was wrong?
Hey, thanks for asking...I should have come back and reported the outcome. I'm kinda embarrassed to say I gave up and had it towed to a shop. They played with it for a couple of hours and called to say it was running now....they had a spare foxbody distributor that they installed and it fired right up. My old distributor, which was a MSD with a Ford Motorcraft PIP sensor had something broken inside (sorry I'm drawing a blank on what it was at the moment) and was causing intermittent function. It was kinda freaky. They loaned me their distributor while I ordered a new one from D.U. I. which has been working great for a few months now. Hopefully that Coyote swap is happening soon...lol
