  • 1994 - 1995 Specific Tech
FPR question and comp question
  • Thread starter Thread starter 95stangGT
  • Start date Start date Jul 24, 2004
9
95stangGT
513
Buffalo, NY
Jul 24, 2004
  • Jul 24, 2004
There is a local guy parting out some of his car since he is going carbed. He has a fox body though so i'm not sure what parts would work. Some of the things I'm interested in would be a kirban or aeromotive FPR, (he has both) MSD distributor, walbro 255 in tank, and a A9L computer for a 5-speed. Right now my car is an auto and i will be converting probably in the fall so would it be wise to just get a fox body 5-speed comp since they are more forgiving on aftermarket parts. Then as far as the rest of the stuff goes, will it work on my car? thanks
R
robertdale
382
kentucky
Jul 24, 2004
  • Jul 24, 2004
The fuel pressure regulators are different but maby you can use the fuel rail off the fox car and then the regulator would work. Also the computer will not be just a straight plug and go. You will most likely need an adapter harness often referred to as a performance improvement harness. Or a lot of wire rigging and a fan controller or switch. The distributer won't work straight up either. The fox cars had the TFI module on the distributor while the sn95 are under the air box. The only part that will work is the fuel pump. Good luck and I would pass on all the parts unless they can be bought dirt cheap then sold.
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
