fresh balanced/blueprinted 5.0 engine
jrwhitley
Ford 5.0 balanced/blueprinted engine
Note: Complete excepting for heads, intake and distributor.
Clean/inspect purchase ford E7TE truck block
$300.00
Clean, magnaflux, turn and polish crank main/rod journals
210.00
Inspect/mic, resurface flywheel
35.00
Bore & hone block
210.00
Balance pistons, rods, crank, flywheel, harmonic balancer
225.00
Hone rods for wrist pin fit
40.00
Install cam bearings, freeze plugs and wash block
85.00
OEM gaskets and seals
76.20
OEM Rear engine cover plate
88.40
Premium piston ring set #SLP-E-458K030
68.99
Speed-Pro forged pistons w/metric ring lands #TRW-L2488F30
351.60
Durashield coated main bearings #FEM-C129M10
92.95
Durashield coated rod bearings #FEM-C87160CH10
97.95
Cam bearing set #FEM-1204M
20.95
Eagle connecting rods #ESP-5090FB
285.95
OEM oil pan
90.00
OEM oil pump
45.00
Stainless oil pump rod
18.95
OEM water pump
45.00
OEM front cover
125.95
OEM tappet set
135.00
OEM factory H.O. cam #F1ZZ-6250-A
75.00
OEM plug and dowel set
12.95
OEM timing chain with matching gear set
289.00
OEM harmonic balancer
75.00
Inspect, mic, assemble, torque to factory specs
1,200.00
________
Total invested:
4,299.84
Asking price: $1,000. or best offer
