Hey can you post up some pics of the vr4? peace
john![]()
Trisha ran a new best... 13.7!
Should I mention how the heads up race went between the burnout queens?!
Almost there misha! Thanks for the pics i thought you were another vr4 i see around here? This one is running gas but also sounds just bad a$$. peace
john![]()
Yes red with a bigger wing and a HUGE intercooler! peace
john![]()
ported heads, stock bottom end, 15G (small upgrade) turbos, 550cc injectors, supra fuel pump, front mount, catback, and downpipe. 12.5@110 without being able to go into 4th. trans problems. it made 396AWHP at 15 psi on a mustang dyno.
the car needs more fuel and driver training. for reference mine has stock heads, stock turbos, smaller injectors, stock intercoolers, stock catback and has done 12.6@113 letting off at about the same place he tops out 3rd. (1000ft)
Have you done anything to your car then? Because from my understanding these cars are quite heavy... (3800 lbs) and the most they came with was 320 hp and a 1/4 time of 13.6. I understand they are all wheel drive, but 12.6 and letting of at the 1000 ft mark doesnt add up with stock hp and weight ratios... Thats fast!
boost controller @17 psi, k&n fipk, downpipe, BOV, 450cc injectors, supra turbo fuel pump (approx 290lph) is it for power mods. i had a lighter hood (19 lbs vs 45lb stock).
im assuming thats where i let off. my hood came off right at the overpass at PIR and i let off when it happened.
