  • 1994 - 1995 Specific Tech
from the midpipe back....
  • Thread starter Thread starter '94ChickStang
  • Start date Start date Aug 12, 2007
'94ChickStang
301
northern ca
Aug 12, 2007
  • Aug 12, 2007
.....my tubing from the midpipe back in my exhaust setup is still stock and the Flows are welded in. What do you think I'm losing in hp if any? I'm currently putting 289/318 to the wheels (which could be better with a better tune imo)
Dino Dino Bambino
1,672
89
79
Cyprus
Aug 12, 2007
  • Aug 12, 2007
The stock dual 2.25" pipes will provide minimal restriction on an engine making up to 400hp at the crank (350rwhp), so changing over to 2.5" piping will probably gain you almost nothing. It's more important to have less restriction at the front of the exhaust system where the gases are hottest and the flow velocity is highest. The gases cool as they travel through the system and their volume decreases, which means that by the time they reach the rear half of the system they can occupy a smaller diameter pipe without adding any more backpressure.
94-302-vert
1,947
NE CT
Aug 13, 2007
  • Aug 13, 2007
I have to say that I think you will gain a little by upgrading... I noticed a slight gain over welded in flows when puttin gon the 2.5" flows with dumps...
Are there better bangs for the buck, absolutely... But if you get a good deal on a used catback it is worth it...
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 13, 2007
  • Aug 13, 2007
I like to relay this info from time to time
Several years ago there was a guy on these boards who had a 347 Stroker
with ALL the goodies.
He was running the stock OEM catback.
He went to an after market catback.
He had a good, reliable, dyno info that showed a gain of 10rwhp
My reasoning says he flowed a good bit more airflow than a 302
soooooo
Typical 302-306 combos are not gonna gain as much
Grady
'94ChickStang
301
northern ca
Aug 13, 2007
  • Aug 13, 2007
good info everyone, thanks
I'll move it down the list then...probably until the flows I have on there are dead
Bosko5.0
1,067
longwood, FL
Aug 13, 2007
  • Aug 13, 2007
I love my stock catback. It makes more torque down low then when I have my cutout open.
94-302-vert
1,947
NE CT
Aug 13, 2007
  • Aug 13, 2007
I changed mine jsut because I wanted LOUD... I wanted to be able to hear it on the highway with the top down, so when I got a good deal on these dumps I jumped on them...
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 13, 2007
  • Aug 13, 2007
I think that is a wise move if you are focused upon making more power
Those pipes are not restricting the flow much at all
Grady
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 15, 2007
  • Aug 15, 2007
IMO the only worthwhile increase in the exhaust dept. you will actually notice would be to ditch the cats. Other than that, I wouldn't mess with it.
With all your engine mods, I think you are pretty close to maxing out your NA HP potential. Plenty of zing, you might want to work on the bling now
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 15, 2007
#10
  • Aug 15, 2007
  • #10
I was kinda wondering about a couple things
Did you ever find the cause of hitting a bump and loss of power
Did you ever post up your pull after getting things sorted out
Grady
'94ChickStang
301
northern ca
Aug 15, 2007
#11
  • Aug 15, 2007
  • #11
naw I've brought the car to the shop 3 times since I got the car back (and again soon) due to it's excessive oil burning! They continue to prove their lack of giving a shi+. It's not burning as much as it was after some vacuum rerouting but my separator still fills quickly, I get a good puff of smoke starting the car after sitting for a while and I get blow by when I get on it hard.
The shop is still working on it for free but it's clearly a low priority
I haven't figured the cutting out but also haven't had it happen in the last couple weeks so the mechanic can't replicate the problem.
I haven't posted my pull yet because I hate knowing 289/318 is low for my combo so I was going to wait until the cooler weather comes to get to a new dyno and have it retuned/repulled. He still has it running a little fat imo
EDIT: But I'll stop being lazy and post the dyno sheet soon!
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
