Most know here i've seen it all run just fine no tune.
I've even seen tunes make things worse and I don't believe NA there is much HP left on the table, so if you think it's being done for more power, most likely you are mistaken.
With that said, 185cc heads are quite large for a NA 302 so is that intake, which is fine, except no chance i'm running that setup with an off the shelf cam, it could leave drivability poor down low, in turn probably taking the tune from optional to required.
This would be a custom situation for me for sure.
The custom cam will also put it in 30's territory.
IMO, worry about the correct parts before you worry about the tune.
