  • SN95 4.6L Mustang Tech
front blinkers...
  • Thread starter Thread starter Onlyoneromeo
  • Start date Start date Dec 5, 2011
O
Onlyoneromeo
  • Dec 5, 2011
on my 97 gt you can barely see my front blinkers. from far away it looks as if they are not on but when you look closely you csn see the bulb filaments flickering . anyone have a clue what might be causing this?
trinity_gt
3,125
81
99
Canada
Dec 5, 2011
  • Dec 5, 2011
Bad ground, corrosion in the socket pins, bad bulb, bad flasher...
O
Onlyoneromeo
  • Dec 5, 2011
Bad flasher ? What's that ? You mean like the relay?
GDawg
1,469
Nevada
Dec 5, 2011
  • Dec 5, 2011
Are they dim only when you are using the blinkers? When the parking lights are turned on are they still real dim? How are the rear ones? Are the blinkers bright there?
O
Onlyoneromeo
  • Dec 5, 2011
Blinkers are OK out back. I do notice blink kind of fast. The fronts don't look like they are doing anything but when you look real close they are blinking .you can see the filament going on n off.
GDawg
1,469
Nevada
Dec 5, 2011
  • Dec 5, 2011
Again, when you turn on the parking lights without hitting the blinkers, do the front light up correctly?
Try removing one bulb at a time and see it the other one goes back to normal. May be just a bad bulb affecting the other good one.
O
Onlyoneromeo
  • Dec 5, 2011
Gdawg ill try that in a few. What I did notice is that when the front lights are off the blinkers work. When they are on they don't. Weird...
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
Help with running lights
  • 93CalypsoConvert
  • Nov 29, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2024
General karthief
