Front Caliper bolts: What size & Grade
94-302-vert
1,947
NE CT
OK, went to start installing the Cobra front brakes yesterday and the front caliper bolts stripped very easily. I hadn't even tried heat yet to get them out as I always try brute force first. So now I have 3 problems.
1. I need new Caliper bolts (what size are these and what grade please).
2. Where can I get these? Would ford still supply them or should I be looking at a hardware store?
3. Are the factory ones loctited in there (ie will heat release them) or should I jsut cut them off with a dremel?
i got my bolts at Pepboys. Comes in a little kit has the bolt and the thing for the other side the tube like thing. But mine are still the stock calipers. Dont know if theres a difference in bolt sizes but i'm sure they should have the one for a cobra if there is
Oh and you can use vise grips or a pipe wrench to get them out don't remember if i used heat on them ones not sure how good that would work around the fluid
