  • SN95 4.6L Mustang Tech
Front Control Arm install
  • Thread starter Thread starter Bluffing024
  • Start date Start date Jun 8, 2006
Bluffing024
Somewhere
Jun 8, 2006
  • Jun 8, 2006
The bushings in my 97 GT vert needed replaced, so I just bought the whole unit with new bushings and balljoints installed already (upgraded arm from 03-04 cobra I believe, ordered from MM). I have a Haynes Manual but it isn't desciptive at all. Does anyone have a write-up on how to remove the front a-arms and re-install them? Any help would be awesome. I have never done any suspension work so again thanks for any help!
Bluffing024
Somewhere
Jun 8, 2006
  • Jun 8, 2006
bump
D
Disturbed One
191
  • Jun 8, 2006
When I redid my suspension not too long ago, I started off by doing one side at a time with the whole vehicle supported on stand in the front. From what I can remember step by step was:
1) Take wheel off.... of course
2) Remove brakes and hang caliper up
3) Remove outter tie rod end from spindle
4) Take Sway bar end link off
5) Place jack under control arm and raise up til arm is held
6) Remove bolts holding strut to spindle, and top nut on strut, remove strut
7) Remove nut on balljoint to take spindle off
8) Lower jack down while standing in front of the vehicle, and take long pry bar and push on the back side of the spring til it pops out.
9) Remove control arm bolts and install new arms.
That's what I can vaguely remember. I don't remember if I loosened the control arm bolts before or after I did this. I think they were loose so the arm would actually fall down when letting the jack down. I didn't have access to a spring compressor so I just stood in front of the car with the jack handle, lowered the arm, and took a long long pry bar and popped the spring out. It did not go flying out when I did mine.
The front bolts holding the control arms on the driver side are not easy to remove and install with the rack in place. I had a hell of a time with is just a warning for ya.
Bluffing024
Somewhere
Jun 8, 2006
  • Jun 8, 2006
I know after I do this I have to get it aligned. Will I be able to drive it to an alignment shop?
D
Disturbed One
191
  • Jun 9, 2006
I don't see why you couldn't. I drove mine after I put it all back together. I had to replace the tie rod ends and I did lower it with the bullitt suspension, along with some camber/caster plates. Mine did pull and it did need to be realigned.
As long as you have everything tightened up, take it in to get it aligned right afterwards. No need to go straight down the road and chew off your tires not knowing better.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
