  • SN95 4.6L Mustang Tech
front end alignment/steering wheel alignment
  • Thread starter Thread starter spederman
  • Start date Start date Oct 19, 2009
spederman
732
  • Oct 19, 2009
Installed a FR500 steering wheel, the steering wheel would only fit on a certain way because of how the tabs lined up. Well because of that, my steering wheel is now a little crooked and turned to the right when the car tracks straight.
My question is that if i get a front end alignment from a shop, do they unbolt the steering shaft when they do an alignment and re-align the steering wheel to be straight with the wheels? (not even sure if thats possible, i dont know jack about front end alignment)
T
TropicMustang
77
Concord
Oct 19, 2009
  • Oct 19, 2009
They will roll your car. Do a caster sweep and then then go ahead and adjust camber and caster if needed. if caster is adjusted they will do another sweep just to verify it, and then to straighten you steering wheel they will center the wheel in the car and adjust your toe settings to straighten out the wheel.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 20, 2009
  • Oct 20, 2009
I have had them straighten out my wheel.
T
TropicMustang
77
Concord
Oct 20, 2009
  • Oct 20, 2009
they straighten it out by setting the toe. There is no steering wheel adjustment on our cars.
spederman
732
  • Oct 21, 2009
thanks guys, i just ended up pulling off the steering wheel and re installing it straight. much easier in the end then having an alignment shop trying to screw with it.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
