Suspension Front lower control arm bushing replacement
  • Thread starter Thread starter JohnG
  • Start date Start date Feb 12, 2022
  • Tags Tags
    bushing lca
J
JohnG
38
San Antonio, Texas
Feb 12, 2022
  • Feb 12, 2022
I am planning on replacing my front LCA bushings, since they are original and the car is close over 275K miles on it. I did the ball joint maybe 8 years ago, so they are good. Has anyone done this successfully? I can find the bushings and understand the process of removing them, but want to know the process of properly pressing the new ones in and getting the dimensions correct. It looks from pictures that they are not pressed in flush. Is this correct? I know I can buy new LCA assemblies, but I want to keep the car as original as possible. Any thoughts or suggestions?
Also, do I need a spring compressor or will the spring release with the LCA at its lowest position/angle?
nickyb
I gotta say i never painted my nuts, Never Ever
3,018
1,652
163
nevada
Feb 12, 2022
  • Feb 12, 2022
I did mine a few years back, got urethane bushings and used existing shells. I just used a drill bit to go around the old rubber bushing and they fell out,then a wire brush wheel on drill to clean the shells. The new ones slide right in no problemo for years of daily driving.
So easy I recently did my rear diff. Uppers, got them from cj pony parts.
TIGGER
877
244
104
Portland, OR
Feb 13, 2022
  • Feb 13, 2022
I did a set for my wife’s sn95 last year. I replaced them with rubber like the originals. Before I did anything I made spacers out of some scrap pipe to keep the flanges from bending in while I was pressing them out and in. Worked good. Took some trial and error on the spacers though. I cut them big and shaved them down till they fit snug.
I used a ball joint kit to r &r the bushings along with my impact.
J
JohnG
38
San Antonio, Texas
Feb 13, 2022
  • Feb 13, 2022
Thanks for your input. I am hesitant to use poly bushings, for one, I have read where the red ones will disintegrate with time, and secondly, I don't want the ride to be any more harsh. I don't track the car, and don't push her hard... much... anymore...
I did find an installation sheet from MOOG (https://www.rockauto.com/genImages/11/AXCF2716.pdf) which states I need a 5/32" gap from the flange to the arm. This answers one of my concerns. I found a washer on eBay with the dimensions I need. I'll cut one side out to make a 'U' and slide it over the bushing as a shim. I also have scrap and a welder, so making an anti-crush spacer is no problem. I was even thinking of welding it in to fully box the end, but probably won't. The spacer should suffice.
I have also read that I need an internal spring compressor for stock springs. Has this been your experience?
manicmechanic007
5 Year Member
Sep 26, 2017
2,549
720
143
Roy, Utah
Feb 13, 2022
  • Feb 13, 2022
They are pretty easy to install and the Ford tools just press them in
The collars Ford sent did not fit perfectly and had to be modified anyway
A big bolt and some sockets and washers and or using bearing races works
A lot of energy in those springs
Just be careful lowering the A arms down and removing the springs
TIGGER
877
244
104
Portland, OR
Feb 13, 2022
  • Feb 13, 2022
Boxing the control arms should make things easier. I didn't want the ride to get any harsher either so I went with rubber as my wifes car was already lowered. Years ago I put urethane bushing in my 67 coupe, and the ride difference was quite noticeable. Unfortunately I have never put stock springs back in any of my cars once I have removed the original springs so I cannot comment. But I would think it would not need much compressing to get them back in.
Willybill32
But at least it's tight!
5 Year Member
Jul 16, 2019
638
359
83
Lexington, KY
Feb 13, 2022
  • Feb 13, 2022
A friend helped replace the LCA bushings on my ‘86 last summer. AutoZone has a kit for removing and replacing the bushings, but the front and rear bushings are different diameters, and one worked OK with the AutoZone kit and one did not. We did the ball joints and tie rod ends at the same time, so it would have been easier, but more expensive, to just take the arms to a shop with all the correct tools.
joncash
just high enough to be functional
756
The USA's peen
Feb 19, 2022
  • Feb 19, 2022
I did a set of Energy Suspension bushings on my old ‘90 and it’s not a bad job, but I did have access to a real press at the time. A torch was used to heat up the stock sleeves until the rubber started burning, then you just push the blob of rubber out like it’s a marshmallow. The excess mess cleaned out easily with a wire brush.
Getting the new ones in was definitely simple with a hydraulic press, so I doubt it would be expensive if you brought the arms to a shop to have it done. Lastly, the car wasn’t any harsher than it already was after switching from rubber to urethane, and with urethane you can leave the metal sleeve in the arm so the position stays the same as it was from factory.
JD1964
there is enough sticking out to grab on to
3,470
1,557
194
Maryland
Feb 20, 2022
  • Feb 20, 2022
To the OP. I‘m not sure what year your car is but heres another option. This search was on 1990 Mustang. Moog has replacement control arms with ball joint and bushings already installed. Depending on what you want, sometimes buying these saves alot of trouble.
Amazon product ASIN B007ZLL3YYView: https://www.amazon.com/dp/B007ZLL3YY/ref=cm_sw_em_r_mt_dp_9VMVA77GGZ0A9CKXXPJQ?_encoding=UTF8&psc=1
Reactions: Dan02gt
J
JohnG
38
San Antonio, Texas
Feb 20, 2022
#10
  • Feb 20, 2022
  • #10
Thanks for the replies. I have watched the poly bushing installs on YouTube, and they look fairly simple. I am trying to keep this car as close to stock as possible. I bought it new, and really like the way it runs and handles. Lots of people sell the complete A-arms, but I have had quite a bit of trouble with the quality of aftermarket parts recently. Also, I am a glutton for punishment. I consider it a matter of pride for fixing, rather than replacing. I did received the MOOG bushings last week and will plan on swapping them out soon. I think I will be renting an internal spring compressor and a ball joint press. I used the press to replace the ball joints many years ago, and it worked well. I am not planning on changing the ball joints in this go, but that depends on how they look when I get in to it.
manicmechanic007
5 Year Member
Sep 26, 2017
2,549
720
143
Roy, Utah
Feb 20, 2022
#11
  • Feb 20, 2022
  • #11
A steal at twice the cost!
Reactions: Dan02gt and nickyb
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 12:05 PM
fasterthangas
F
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
