Front oil drain plug
groupbmonster
10
Is the front drain plug on the oil pan for an 89 look about the same as the rear plug? Like a bolt head?
I talked to a friend and he has a 90 and his front plug is the same style as the rear. But my front is a type that doesnt have a head like a bolt, it is round and looks as though its made to be tightened by hand.....hard to explain and i cant currently get pics.
Anyway its leaking and i wanted to try and get a new gasket for it (its actually almost like a grommet) but couldnt find anything that matched what i have. i could only find the rear plug.
The pan changed in between 89 and 90 correct? thats why id need a new pickup to use the newer pan.
Any input will help. thanx
I 3rd that-its probably rounded. But what you can do is run down to your local ford dealership and get 2 new drainplugs. I think ford had recalled those older drainplugs with stupid gaskets that leaked. They have new drainplugs with plastic gaskets that dont leak. I had the older onse on my car, switched to newer ones and now no more leaks :D
thanx guys.....its definately not a rounded bolt head.....not even close , i wish i could get a pic for you guys. im wondering if the threads in the pan were stripped and replaced with something different seeing as you all seem to have a bolt there. anybody ever seen a stripped bolt replaced with something completely different in this situation before?
If it wont come out, you will want to find a way to fix it or a means of vacuuming out the front hump during oil changes since ~.75-1 quart get stuck up there.
Do you see any carnage to the inside (rearside) of the anti-sway bar?
Good luck.
I've seen some pretty weird plugs that are designed to go in once the threads have been stripped out, some of them were hand-tightened I believe. You may well have something like that.
I have also seen and installed some weird looking drain plugs, like the type that yave a little lever on them and you hold it down while the oil drains out. its kinda a quick way to drain your oil but i dont trust them.
