Front power disc brakes conversion kit recommendations
  • Thread starter Thread starter my70stang
  • Start date Start date Jan 23, 2006
my70stang
156
Arizona
Jan 23, 2006
  • Jan 23, 2006
i want to switch my 70 mustang from manual 4wheel drum brakes to front power disc brakes. also, were switching my engine in a while to a V8 so were going to swap my 4-lugs to 5 lugs and want a "beefier" rear end.
any help would be appreciated
my70stang
Edbert
3,548
32
109
Austin TX
Jan 23, 2006
  • Jan 23, 2006
8" rears are dirt cheap and quite reliable for mild driving up to ~375 fwhp.
Regarding the front power discs there are many options, can you give more insight into your budget and expectations?
dawtips
56
  • Jan 23, 2006
I just installed this kit on my '69 stang and it went pretty smoothly. The brakes feel great.
http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400336
wild70stang
317
  • Jan 23, 2006
once I get $500 I was going to invest it in a granada brake set up with slotted rotors for better braking. Heres the site.
http://www.discbrakeswap.com/
'69Mach1
45
Northern N.J.
Jan 23, 2006
  • Jan 23, 2006
R/C Motorsport makes a nice kit for less than $400 ,all you would need is v8 spindles.Or you could look for a used Mach1 setup ,and you would have the whoul setup.
Big_B
121
Sacramento
Jan 23, 2006
  • Jan 23, 2006
I would recommend searching the forum. There are probably hundreds of threads with discussions of various options.
LMan
1,246
Mom's basement
Jan 23, 2006
  • Jan 23, 2006
JeeZUS....how many times are we gonna cover the same ground?
lol
8cuda
South Bay, Nor Cal
Jan 24, 2006
  • Jan 24, 2006
I'm in the middle of adding 1973 Mustang front disc brakes and ultrastang's Lincoln Mark VII rear disc brakes to my 1969 fastback. Mustangsteve's Cobra front kit looks very nice. I wish it came out before I began collecting parts for my swap
shotsy
233
Oklahoma City
Jan 24, 2006
  • Jan 24, 2006
I used the Master Power Brakes kit
http://www.mpbrakes.com/mp4.htm
on my 70 coupe and love it.
It was a bit spendy and I have to run a vac can because of the cam I'm running but it stops almost as fast as it starts
R
rob289c
81
#10
  • Jan 24, 2006
  • #10
Power Disc Brakes
I also bought the MPB kit for my '67. Haven't installed it yet but it looks to be a complete kit and pretty straightforward install. It ended up being about $900 and included rotors, 4-piston calipers, hoses, vac booster, MC, combo valve, attaching brackets and hardware. I'm sure it will be quite an improvement over my 4-wheel, non-power drum setup.
Rob
5.0ina66
664
Ohio
Jan 24, 2006
#11
  • Jan 24, 2006
  • #11
Rod & Custom RC132 kit $350. Adj prop valve $40. 1990GT booster $90 (use with manual pedal) 69 PDB MC $25. I know the 67-68 I6 & V8 spindles are the same, AFAIK the same is true for 69-70.
bnickel
5,640
lubbock, texas
Jan 24, 2006
#12
  • Jan 24, 2006
  • #12
that price is going to be hard to beat and I know degins has put a lot of work into getting that kit together.
the only thing i would like to see different is the use of stock 68-73 style caliper brackets and calipers so the kit would be more OEm style but this is still a great deal for a disc swap.
xoxbxfx
3,959
Southlake, TX
Jan 24, 2006
#13
  • Jan 24, 2006
  • #13
i have a 69-70 disc setup if you are interested in... Needs to be cleaned up, rotors may be able to get turned, but its complete minus brake lines. Also have a brand new master cyl for it. Let me know if you are interested, was gonna use it on my 69 but I have a MII suspension layin around im gonna use
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
