Well.... my car is LOW. I have KYB shocks and noticed that there is only 1 1/4" of shock shaft left after install. I measured the shock shaft when removed from the car and it is 4 1/2" long. Looks like I need a shorter shock so I don't bottom this one out and ruin it or worse yet, send it through my fiberglass hood in the event of a hard bump. Does anyone know where I can get a shock that is about 2 - 2 3/4" shorter? (I called KYB, they don't make one) I have a 64 coupe and am using stock style shocks (two studs on the bottom that go into a roller perch and the T bar on top that bolts to the shock tower caps). Any shock will do, I just want something that will fit and not bottom out! Thanks for your help.
