front spring removal help
  • Thread starter Thread starter shelby69
  • Start date Start date Feb 20, 2006
shelby69
100
allentown
Feb 20, 2006
  • Feb 20, 2006
I am trying to take the front coil springs out of my 69. I have a tool that bolts on the spring perch (were the shock would normally go). I have unbolted the sway bar end-link and lowered spring and control arms. There doesn't seem to be very much tension on the spring, but I don't want to get hurt. Do I need a compressor that hooks to the spring so I can unbolt the perch first? Any help is appreciated.
zookeeper
3,415
63
109
Rogue River, Oregon
Feb 20, 2006
  • Feb 20, 2006
I'm not sure what you mean by " a tool that bolts on the spring perch", but here's my favorite way to safely remove Mustang front springs. I put the car on jack stands, take off the front wheels, then unbolt the sway bar from the control arms. Then unbolt and remove the shock, as well as the shock tower supports that are inside the wheelwell (tire side) and are held on by 6 bolts per side. This pretty much exposes the whole spring so you can see what's going on in there. Then beg, borrow or buy a spring compressor. I prefer the type that goes inside the spring, since you can compress the spring quickly with and impact gun, reaching down from the top through the shock tower, but any coil spring compressor will work. Once you compress the spring, it easily comes right out, and if you're cutting your springs (I did) or using shorter aftermarket springs, you may not even need the compressor to put them back in. Good luck and be careful!
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Feb 20, 2006
  • Feb 20, 2006
Leave the perch alone; you only want to compress the spring.
1320stang
4,329
23
89
Edmond, Oklahoma
Feb 20, 2006
  • Feb 20, 2006
You should be able to rent the tool from an auto parts store. Around here, you can rent these type tools from O'Reilly's or AutoZone. Basically, you pay for the tool, then bring it back for a full refund. Cash, check or card works. Just make sure that when you rent the tool, it has all the pieces there. I once rented a puller and one of the previous renters lost some of the bolts I needed.
shelby69
100
allentown
Feb 20, 2006
  • Feb 20, 2006
Thanks for the quick replies. I will have to borrow a real spring compressor and try again.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
