Front suspension rebuild?
  • Thread starter Thread starter 65cpe69mach1
  • Start date Start date Aug 13, 2004
65cpe69mach1
52
Dallas, TX.
Aug 13, 2004
  • Aug 13, 2004
Front suspension rebuild?... DIDN'T get done!
Am planning on replacing the lower control arms, strut rods and upper ball joints this weekend. Have two 2 1/4 ton jack stands and a floor jack along with assorted hand tools.
How long, on average, might this take me to do? Never done it before and need to have the car driveable come Monday.
Also, if I were to install new coil springs, how do I use the coil spring compressor tool? Should I put the end of the new coil spring in a vise? I'm just figuring that theres only so much compressing I can do on a new spring before it just starts turning in my hands.
O
Ozsum2
695
  • Aug 13, 2004
I'm going to suggest you get ahold of a manual. You will need an alignment after doing the lower control arms and struts. A vise would be helpfull, but is not needed. It could take most of a day.
65cpe69mach1
52
Dallas, TX.
Aug 13, 2004
  • Aug 13, 2004
I've got one of the Mustang/Fairlane manuals.
O
Ozsum2
695
  • Aug 13, 2004
Glad to hear it. Super Dave was a strong proponent of the Ford Shop Manual for a good reason. Many on here start a project, only to get in over their heads and cry for help. Good luck.
HistoricMustang
2,359
Confederate States of America
Aug 13, 2004
  • Aug 13, 2004
I am with Ozsum2 on this one believe it or not.
HistoricMustang
www.historicmustang.com
65cpe69mach1
52
Dallas, TX.
Aug 15, 2004
  • Aug 15, 2004
Started to work on my front suspension rebuild this weekend and ran into a big problem.
Went to remove the lower control arm pivot bolts and the bolts where previously installed with the head of the bolt on the oil pan crossmember side, not towards the front of the car. Well so then I tried to remove the crossmember... no go. The bolts wouldn't budge at all.
Checked the shop manual and it mentions nothing about having to remove the crossmember so thats why I figure some wanker went and put them in backwards.
If I can't get the oil pan crossmember off I guess I'll need to borrow something to cut the lower control arm bolts off and install the new bolts with the heads facing toward the front of the car.
Anyone else ever run into this kinda crap?
Very frustrating.
65fastback2+2
1,229
Louisville, KY
Aug 15, 2004
  • Aug 15, 2004
Very frustrating.
thats how they are supposed to go. I just redid my complete front suspension this past week. Thats how the bolts are supposed to go. If they were the other way you wouldnt be able to get a nut on them. You can get the oil pan crossmember off, just wd40 the bolts, and put some ooomph on em, or get an impact with 110 psi . They usually help bust em loose jumping around on the nut. Ive taken 2 off before and both came off in 10 minutes.
btw, no offense to those who recommended a shop manual, but, i have a 68 shop manual, and I redid the front suspension without the manual. Just tear one side down and rebuild it, that way you can look at the other if you have questions. The only thing I messed up on is I didnt leave the lower control arm bolts loose and put the car on em, I tightened em while the car was on stands.
65cpe69mach1
52
Dallas, TX.
Aug 15, 2004
  • Aug 15, 2004
Unfortunately I don't have an impact wrench or any air tools to use. Did try some penetrating spray. Also used another wrench locked onto the one I had on the bolt. Could see both wrenches starting to flex but the bolt wasn't moving.
Is this bolt screwed directly into the frame? Didn't find a nut that it was screwed into.
So what other ideas do you guys have?
65fastback2+2
1,229
Louisville, KY
Aug 16, 2004
  • Aug 16, 2004
well, i got both of mine on the 65 and 67 off with just a socket, the impact was just an idea for getting it loose. It is just screwed into the frame. Your your legs or a big hammer. Just try and either hammer the socket or wrench with like a 3-5 pound hammer OR push on it with your feet while holding onto the car, both very effective this past week when i ripped it all apart
R
Ronstang
1,294
Houston Texas
Aug 16, 2004
#10
  • Aug 16, 2004
  • #10
Go to bed Jason or you won't get the rear suspension done in the morning and you will run out of time this week.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Aug 16, 2004
#11
  • Aug 16, 2004
  • #11
Try a Socket with a Breaker Bar and a Long peice of Pipe.
PB
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
T
Suspension 1988 Suspension
  • TeamGMS
  • Feb 5, 2025
Fox 5.0 Mustang Tech Feb 5, 2025
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
