My front tires, specifically the front left tire, is cupping on the inside of the tread. Every other tread block on the inner edge is really cupping while the other tread blocks are wearing normally. I don't feel anything odd going on in the steering. This is making my tires really noisy. Here is my set up:
86 Capri 5.0L with Bridgestone Potenza Eager tires on stock 10 holes
11 inch rotors, cross drilled/slotted mounted on later spindles
Lincoln Continental brake calipers with Bendix Titanium Metallic pads, calipers mounted with Steeda stainless bushings
Subframe connectors, K-member brace, strut tower brace, poly sway bar mounts
257,000 miles on all front-end stuff except the struts and wheel bearings
I feel nothing in the steering that's out of whack. In fact, it feels really tight. No obvious loosness on wheels up/down or side/side. Ball joint indicators look good.
Ideas?
Thanks,
Mikey
Ideas?
Thanks,
Mikey
