Frozen collector bolts, help!!
jmd2914
937
Napa, California
i replaced the studs that connect the header to the x pipe with hardened bolts with a nut on the other side, now the nut came off when i tried to take the x pipe off however the bolt seems to be frozen. impact gun isnt working and penetrating fluid isnt either. any ideas?
i had similar problem, it sucked, i had to get my cut off tool and cut my H pipe near the 02 bung and pull the header out through the engine bay. Then i had to cut the studs bcthey were still stuck in the header so the head i had to throw away and buy another set and use the piece of my h pipe and hook it back up with exhaust wrap and go to the local shop and have it welded, it was a B I T C H!
if the part is threaded, you can try to heat it up then attempt to unscrew it. i would go straight to mapp gas, over the propane. if you access to an oxy/acel setup, that is ideal. if not, you may have to remove the header and drill it out.
