This idea just came to my mind for some reason. If I wanted some 3.90 Gears, but wanted them to be FRPP Gears, could I just use the 39 tooth ring gear from a set of 3.55's and a 10 tooth pinion from a set of 4.10's to get a 3.90 gear ratio. Sounds good on paper, but would this work?
I guess the remaining ring&pinion would make a set of 3.73's.
*Edit
I guess if it actually worked, there would be no reason why Ford wouldnt sell 3.90 gears. I think I'll go to bed now and stop coming up with crazy ideas.
I guess the remaining ring&pinion would make a set of 3.73's.*Edit
