FRPP Blower question
EXTRPR50
370
I have a 95 GT and am not familiar with the 4.6's. So does anyone have the FRPP blower for your cars? If so , how is it? Does it do the trick, or are there better blowers for the money?
Thanx
ps, Im thinkin about going to this setup.
The only positive displacement type blower available for the early 5.0L cars are the Kenne Bell Blowzilla/Flowzilla, or if you can find one an old BBK kit. Otherwise, you're going with a centrifugal blower baby, cause the FRPP set up is Modular Specific.
Thanx
For a 4.6 car if you want a positive displacement blower you can walk right past the FRPP kit and go to the Kenne Bell blower - www.kennebell.net. It's a much better blower. And the KB will support 9+ psi quite easily as it is available with an intercooler. The FRPP has a practical limit of about 6-7 psi and has no intercooler set up available.
You know the "install kit" cost over a thousand dollars on top of the cost of the blower? You also don't hhave the option to intercool. I've also read it good for only about 50HP gain or so. Perhaps a different pulley would up that but the FRPP blower you are thinnking of for the modular is not a good investment.
Yeah, I said I had a 95 to let u know that Im not familiar with 4.6's. I wanted to know about the blower in case I got to a 99-2004 GT. I am still learning about these engines. There dont seem to be alot of inexpensive parts for the 4.6 like you can get with 86-95's. So I was just thinking about going straight to a blower, in one big add on. I like the body style (fender flares) and edges.So I may be in the market soon. Im just testing the waters on performance upgrades
They aren't as cheap or easy to modify for more power. I used to think this was an indicator tha they were inferior to the 302. But I know realize that the 4.6 is far and away a better engine. The 302 as good as it is (and I have a 90 5.0 and love it), is horribly inefficent as delivered from Ford. That's why it responds to the cheap mods you speak of so easily.
The 4.6 is much more highly tuned as delivered. The small tweaks you can make to a 5.0 are already done to the 4.6 to make it produce the power it comes with at the factory. That doesn't mean you can't add a lot of power without too much trouble. Many have added 40-50 rwhp with some realitivly simple bolt on's. The big thing I see that seperates the 5.0 from the 4.6, as far as getting any substantial gains comes from, is the electronic tune. The 4.6 really seems to like the tune. The 5.0 likes it too but not as much as the 4.6 does it seems.
Oh yeah.... the 2 things you'll notice right off the bat with the change to the 4.6 is 1st, it will have a softer torque hit down low. 2nd, it will rev way higher and continue to make power up top than the 5.0 HO ever thought about doing.
One other thing. 5.0 responds well to gears right? The 4.6 responds great to gears. They practically beg for them.
SilverHorse said:
I may be wrong but I don't think the FRPP blower fits PI heads. I think I've read that in a few places.
there is a kit for the PI heads now...A member on this board installed it on his PI swapped gt.(green fow six) He gained almost 100 rwhp from the 6lbs of boost. And they do gain more with the 9psi pulley. The frpp blower is no Kenne Bell for higher HP setups....but for a nice reliable street blower it is a good choice. There is a huge thread about it on here...with dyno results etc.
Here we go again. Yet another "Kenne Bell blowers are better than god" post. When will some of you people learn? :rolleyes:
Wrong. I don't think it's "better than god", but I do think it's better than the FRPP Eaton blower.
He sai dhe was new to 4.6 and was askigfnabout positive displacement blowers. Well that means you can look at FRPP, Saleen and Kenne Bell. No one else makes a kit for the 2V 4.6 that I know of. Whipplecharger should, but as far as I know they don't......well, actually they do I guess. They make the Saleen kit.
And just to gain some perspective, and because I'm curious, what is your meaning behind "When will some of you people learn? :rolleyes:"? What's your beef with the KB blower?
In what aspect, overall power? Sure, when you spin the KB’s hard, they’ll walk away from the FRPP pretty good. But what else makes them superior to the FRPP? They’re no more powerful at low boost levels (7psi and below), far more expensive and have no where near proven more reliable than an Eaton blower that’s done so time and time again over the last 15-20 years on various vehicles. The KB is a good blower.....I’ll even go as far to say a great blower, but it’s not the only blower worth having. For you to suggest that someone should skip over the FRPP or others and choose the KB based solely on power is a pretty uniformed statement. If that were the case, wouldn’t it make more sense for them to "step right over" the KB and go with a Novi 2000 or a T-trim? You gotta cover all the bases man. :)
Saleen blowers come in both Eaton and Whipple based, depending on the model. You're also forgetting Allen Engine Development and Roush as well as Whipples own line of Twin Screws. There are only two major types of blower. There are Roots (Eaton) and Twin Screws (Auto Rotor, Whipple). Each of these companies makes different kits available with different types of blower (except for Kenne Bell). That leaves a very wide variety of high quality packages to choose from.
No beef at all. I already stated above that they are in fact a great blower. It just annoys me when everything else is dismissed because so many have blindly jumped on the KB bandwagon and no actual factual advice or experience to back it up, just blanketed "one sentence" statements/comments. What’s most important is picking the right tool for the right job. No one blower covers all avenues. Otherwise, they'd all be the same.
All valid points and I did over simplfy my statement. IThe screwcharger that KB uses is by far more efficient. It adds less heat to the compressed air charge and the 9psi version of the kit is intercooled which allows much mor erom for greater boost levels and higher timing setting which all add reliability and most importently power (both lbs-ft and hp) to the engine over the FRPP setup. The KB and Whipple charger blowers have repeatedly shown that boost psi to boost psi the screwcharger adds significant ammounts of power over the Eaton.
In an issue of MM&FF they ran a 2003 Cobra with the stock Eaton and a KB or whipple (not sure which and they are almost the same). At the same boost level the KB/Whipple made more power and ran cooler than the Eaton. This prooved to particularly importent as boost levels increased. However, even at the stock boost level the KB/Whipple unit made more power and not 5 more closer to 40 more if memory serves.
That is why I went to the KB blower over the FRPP.
