frustrated
  • Thread starter Thread starter cliff88145
  • Start date Start date Feb 28, 2006
cliff88145
87
Feb 28, 2006
  • Feb 28, 2006
I just got a 1988 saleen bone stock but when I test drove it, it was hard to get into gear. I thougt it was the clutch cable. I replaced the cable and the same thing. So I replaced the clutch, same thing. I replaced the tanny with a tremec from summit, some thing. Where do I go from here?The clutch padal is so hard to push down to get into gear.
ram360
2,162
Pennsylvania
Feb 28, 2006
  • Feb 28, 2006
Hows the clutch quadrant? What clutch did you put in? I'd say mess with the adjustment, if you have too much slack in the cable the pedal it will not fully disengage and make it hard to get in gear.
cliff88145
87
Feb 28, 2006
  • Feb 28, 2006
I replaced the plastic one for the bbk aluminum one
ram360
2,162
Pennsylvania
Feb 28, 2006
  • Feb 28, 2006
what clutch did you put it?
M
matm347
2,056
  • Feb 28, 2006
What is your problem, pushing the pedal down or getting it into gear.
Do you know if you have a firewall adjuster?
cliff88145
87
Feb 28, 2006
  • Feb 28, 2006
No fire wall adjuster.I have to adjust it from under the car.It is very hard to get into all gears. I put in the ford clutch from summit not the cobra
ss93cobra
1,422
Wilmington NC
Mar 1, 2006
  • Mar 1, 2006
Aftermarket shifter?
If so, sounds like I'd look at the adjustment stops...
1991vert
1,103
Ludlow, MA
Mar 1, 2006
  • Mar 1, 2006
shift stops are there so you dont "overshift" and bend a shift fork. he can't even seem to get it into gear, so i would rule those out
ss93cobra
1,422
Wilmington NC
Mar 1, 2006
  • Mar 1, 2006
unless they're adjusted in too far....
1991vert
1,103
Ludlow, MA
Mar 1, 2006
#10
  • Mar 1, 2006
  • #10
dunno if it's aftermarket or not yet could be either. but im guessing stock because everything else was? stock tremec shifters dont have shift stops.
87GTSnake
96
PA
Mar 1, 2006
#11
  • Mar 1, 2006
  • #11
If the shift stops were adjusted to close to the shifter than you most likely would not be able to get it into gear at all, and if you could it would most likely then pop out of gear due to the shifter hitting the stop under acceleration.
So if you ask me, this problem has nothing to do with shift stops.
1SLWGT
12
JOPLIN, MO
Mar 1, 2006
#12
  • Mar 1, 2006
  • #12
How is your linkage routed? Sometimes it can get in a bind.
cliff88145
87
Mar 1, 2006
#13
  • Mar 1, 2006
  • #13
It has a pro 5.0 shifter.I dont no about the linkage but the tremec is new and I had the same problem with the T5. with only 80k miles on it.
troyGT03
278
too close to memphis,tn
Mar 1, 2006
#14
  • Mar 1, 2006
  • #14
your clutch fork may be bent???? how much free play in the clutch pedal? where does the clutch engage when you do get in in gear?
1991vert
1,103
Ludlow, MA
Mar 1, 2006
#15
  • Mar 1, 2006
  • #15
take a few trips to the gym, you might just need some muscles... jk. id say invest in a firewall adjuster.
89white50
440
central MA
Mar 1, 2006
#16
  • Mar 1, 2006
  • #16
my FRPP HD clutch is stiff as hell, and as a hockey player...i love it. My dad has a very wide foot and has trouble getting my car into gear. His foot hits the dead pedal which doesnt engaged the clutch enough. This is because i have the Jegs high ramp quadrant. Which makes the pedal effort much short, but makes it so you need to push it in further than a stock quadrant. Somehow im guessing your not engaging the clutch fully.
oh it has nothing to do with muscles either, my father has 19'' calves
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
