FUEL DELIVERY
  • Thread starter Thread starter 1SLWGT
  • Start date Start date Mar 18, 2006
1SLWGT
12
JOPLIN, MO
Mar 18, 2006
  • Mar 18, 2006
I JUST INSTALLED A NEW FUEL PUMP IN MY CAR AFTER THE OLD BBK 190lph WENT BAD. IT IS A HOLLEY 155lph. AFTER INSTALLATION, WHEN GOING AROUND A CRONER W/LESS THAN 1/4 TANK OF GAS, IT WILL LOSE POWER. WHEN THE CAR IS STRAIGHT AGAIN, IT RUNS FINE. THE BBK PUMP DID THIS TO ME ALSO. I HAVE PULLED IT BACK OUT AND RE-INSTALLED IT MAKING SURE THAT I DIDN'T GET HUNG UP ON ANY OF THE BAFFLES. STILL THE SAME PROBLEM. ANY IDEAS??
Repostyle
538
Portland, OR
Mar 18, 2006
  • Mar 18, 2006
The pump loses power or the engine loses power? Sounds like a loose connection in the wiring if the pump is losing power. Check your mercury switch and make sure it's secure and upright.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 19, 2006
  • Mar 19, 2006
If the spot welds that secure the baffle in the bottom of the tank break, the baffle will move and allow the fuel to slosh away from the pump pickup.
There is no mercury switch in the fuel pump electrical system. There is an inertia switch that shuts the pump power off if the car is hit in a collision
If the pump loses electrical power while the engine is running, it will set a code. Dump the codes and see what the computer says is wrong.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
