Fuel Evap System
  • Thread starter Thread starter jcnunez85gt
  • Start date Start date Jul 7, 2009
J
jcnunez85gt
17
San Diego
Jul 7, 2009
  • Jul 7, 2009
So i took my 85 gt to smog and it passed emissions but they hooked a computer to the gas tank which tested the fuel evaporation system. I dont know what that is but i need some help to figure out what that is. Any advice?
HISSIN50
34
129
Jul 7, 2009
  • Jul 7, 2009
Did it fail for the cap or for something with the tank?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 7, 2009
  • Jul 7, 2009
The code 85 test path will help you get some ideas on what the system looks like and how it works...
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative or missing. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
Purge valve solenoid:
Carbon Canister:
J
jcnunez85gt
17
San Diego
Jul 7, 2009
  • Jul 7, 2009
they connected what looked like a gas cap to my gas tank and that is what failed.
thanks for the diagram ill check that today.
HISSIN50
34
129
Jul 7, 2009
  • Jul 7, 2009
But what failed? What was it testing for? Was it a pressure test and the gauge didn't drop to zero quickly?
tim281
125
Portland, OR
Jul 7, 2009
  • Jul 7, 2009
Filler neck gasket or routing to carcoal can... Maybe bad solenoid
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
EVAP test port
  • bigc2330
  • Oct 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 1, 2025
nickyb
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 30, 2026
