EVAP test port
bigc2330
79
2000 GT
The hose with the test port for my EVAP system needs to be replaced, but I cannot find anybody that sells it.
Does anybody have a link to the part?
If not, can I pull the test port out of the bad hose and put it into a new rubber fuel line as a replacement or can I just cap it off at the Y port or get ride of the Y port in general?
Thanks for the links. Those will definitely help with the rest of the system.
The hose I was referring to comes out by the front passenger side shock tower, it has a green cap on it with a schrader valve inside it. I read some where that it is a “test port” to find leaks in the EVAP system. It connects with other hoses behind the front passenger side fender.
I know that green cap from when my wife's Taurus(2004) had an evap leak.
Ford discontinued many of those parts, I believe pic a part would be your best bet.
Reactions: bigc2330
