I could tell you how to do it. Trip the inertia switch, so your fuel pump doesn't turn on. Start the car and let it idle until it dies (few seconds max) in order to relieve the fuel pressure. The fuel filter is in front of the gas tank mounted side to side. Loosen the clamp, pop off the retaining clips, pop out the old filter (you'll get soked in gas, so be careful), pop in the new filter, tighten the clamp, and reset the intertia switch. Cycle the ignition several times to build fuel pressure and check for leaks. You're done.
