  • SN95 4.6L Mustang Tech
Fuel Filter reminder
  • Thread starter Thread starter Alex46
  • Start date Start date Mar 16, 2010
Alex46
50
  • Mar 16, 2010
I am Very good about changing oil, plugs, all the reccommended parts before the mileage in the book etc.
But one thing i had forgotten about was the fuel filter. Factory calls for every 15k, but i thought with the sea foam and other similar products i was using that it would be ok. Went 22k on it and was amazed on how clogged it was. Gas was barely dripping when i hit it to the ground and you could barely feel the air when blowing through it.
After i got the new one in it was almost like a new set of plugs were put in.
Know a lot of you are very great with this, just wanted to remind those who cars aren't running quite like they were. Aside from running better also get better gas mileage i would think. Not much, but i highly recommend it guys. Just one of those parts that at least i forget about sometimes.
Regards,
Alexander
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Mar 17, 2010
  • Mar 17, 2010
Most definitely! I change mine about every 10k miles personally...
sneaky98gt
2,387
144
114
NC State University
Mar 17, 2010
  • Mar 17, 2010
Good reminder. I changed mine a few months ago (for the first time in the 4 years I've owned my car) and mine was the same way.
Also a reminder, make sure the pressure is off the fuel system before you take it off....made that mistake too....
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 19, 2010
  • Mar 19, 2010
Also, not so much as mileage, but age too. My 2004 Cobra has 8,900 miles, but it's 6 years old. It sits a lot. I should think about changing mine.
Also...use a Motorcraft. Do NOT buy FRAM or off brands to save a whopping 2-3 dollars. People have posted of lost fuel pressure with FRAM.
D-BOI
596
Metro Detro
Mar 19, 2010
  • Mar 19, 2010
uhh mine has 84k probably on the stock one, how do i release the fuel pressure and where i the filter located sounds like i have to do this asap
SVT32VDOHC
3,501
28
119
Motor City
Mar 19, 2010
  • Mar 19, 2010
I take the fuel cap off to start, but you should also find the shrader valve on the fuel rail and press the valve down. CAUTION: Fuel will spray with force for a second. Watch your eyes, children, and do it on a cold engine.
nancygrl
257
Mar 19, 2010
  • Mar 19, 2010
Here's a good procedure with pictures. Not only for the fuel filter, but the guy has a bunch of good maintenance procedures and info.
BULLITT Fuel Filter Change
The site helped me alot when I changed out my rear diff fluid.
fiveoho
1,958
TN
Mar 19, 2010
  • Mar 19, 2010
nice informative site nancy
D-BOI
596
Metro Detro
Mar 19, 2010
  • Mar 19, 2010
Thank You Guys and Gal***
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 19, 2010
#10
  • Mar 19, 2010
  • #10
The Bullitt Archive rocks.
spederman
732
#11
  • Mar 19, 2010
  • #11
is the only place to get a motorcraft fuel filter locally at the ford dealership? or does walmart/autozone carry them like they do motorcraft oil filters?
nancygrl
257
Mar 19, 2010
#12
  • Mar 19, 2010
  • #12
I just checked and Advance Auto carries it.
Part No. FG986B
Warranty: 30 DAY REPLACEMENT IF DEFECTIVE
MFI; w/ 16 Valves; Type: 209
$12.99
Alex46
50
#13
  • Mar 23, 2010
  • #13
Nancy, Thank you very much for the link. Never knew about the site. Got some great stuff on there. Greatly appreciated
D BOI Hard to believe you made it that long without some types of clogs or fuel pump problems. Was hoping this thread would help at least 1 person. Glad it did. And very glad about the link.
Also what SVT32 was mentioning, yes be Very careful. When i was 16 i did it on my 5.0 and you have not felt pain until you get gas in your eyes and ears. Where some goggles if you can the first time you do it. Don't mean to make it sound hard by any means. Just be careful. Was a little younger, but whew that hurt
Thanks for all the information everyone
sneaky98gt
2,387
144
114
NC State University
Mar 23, 2010
#14
  • Mar 23, 2010
  • #14
I'm a couple of days late, but here goes. Yea, you can push the schrader valve and that works fine. But what I do is unplug the plug right under the rear bumper/behind the fuel tank. It's very easy to get to, and all you have to do is push in a tab and the two ends of the plug pull apart from each other. Then, turn the car over for a bout 10 seconds, or until it stops hitting any more from the fuel.
I prefer the second method because it doesn't require getting fuel spray everywhere, and if you have a fuel pressure gauge in place of the schrader valve, you can't exactly just take it off. The second method is very easy to do and takes about 30 seconds.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Mar 23, 2010
#15
  • Mar 23, 2010
  • #15
Part No. FG986B
$12.99
Shes a great addition to website, this place needs some female opinions.
spederman
732
#16
  • Mar 23, 2010
  • #16
Part No. FG986B
$12.99
picked one up at O'reilly's since we dont have advance auto.
Also, if the car sits for 24 hrs or so, isnt the fuel pressure released by itself anyways?
D
Is this a fuel filter?
  • Dutch74
  • Oct 2, 2025
1974 - 1978 Mustang II Talk & Tech Oct 21, 2025
welder4956
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
