  • SN95 4.6L Mustang Tech
Fuel Filter Replacement Question
  • Thread starter Thread starter JetBrett
  • Start date Start date Jun 2, 2006
JetBrett
384
Sammamish, WA
Jun 2, 2006
  • Jun 2, 2006
I'm going through my Hayne's manual instructions to swap out my fuel filter. It is instructing me to use the fuel shut-off valve in the trunk and then run the motor until it cuts out to de-pressurize the system. I'm worried that this could harm the motor especially since I'm running a supercharger. Does anyone know of a way to de-pressurize without running the motor dry (am I being overly cautious on this?) or has anyone changed the fuel filter without de-pressurizing the fuel system...do you get a full tank of gas on the garage floor if you do this? Thanks for the help.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 2, 2006
  • Jun 2, 2006
http://www.bullittarchive.com/1009.htm
jstreet0204
939
Winston Salem, NC
Jun 2, 2006
  • Jun 2, 2006
Running the motor out of fuel at idle not hurt the engine.
89lxsport50
550
Franklin Tennessee
Jun 2, 2006
  • Jun 2, 2006
I have always unpluged the inertia switch on my 89 and started it up. It would only run for a few seconds before it ran out. I recently bought an 02, and tried the same thing. It just kept running. I reved it a couple times and it still ran. I just turned it off and replaced the filter. Only a few drops of gas came out of the line.
Nater
239
Maplewood, MN
Jun 2, 2006
  • Jun 2, 2006
Same thing with mine. I turned the engine off and let it sit for a while. I even unplugged the fuel pump by taking out the fuse in the fuse block and for some reason it still ran. Not good, but it ran.
JetBrett
384
Sammamish, WA
Jun 2, 2006
  • Jun 2, 2006
cool....thanks all
jstreet0204
939
Winston Salem, NC
Jun 2, 2006
  • Jun 2, 2006
Mine will usually run for a good 20 minutes before it dies.
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Fuel Damper, 2003 Mustang GT
  • bmmckl
  • Dec 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 19, 2025
bmmckl
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
