  • SN95 4.6L Mustang Tech
Fuel Filter Replacement
  • Thread starter Thread starter SPKMustang
  • Start date Start date Mar 11, 2004
SPKMustang
87
Amherst, NY
Mar 11, 2004
  • Mar 11, 2004
Where on an 01 GT would the fuel filter be located? Also what is involved in changing it? What brand do I need etc? Should I just go to the dealer and ask them for what I need? Thanks for any help you guys can provide!
SK
XTONKAX
619
UT
Mar 11, 2004
  • Mar 11, 2004
SK
The filter is just in front of the tank under the car. You'll need a spring lock tool which can be purchased at an auto parts store. They should also have your filter. Inside your trunk (left side, rear I believe) is a connector you need to disconnect to relieve fuel pressure. (Fuel cutoff switch)? Regardless, expect some residual fuel spillage. Wear goggles and have some towels handy. Good luck!
SPKMustang
87
Amherst, NY
Mar 11, 2004
  • Mar 11, 2004
ok cool I know where the fuel shut off switch is, so thats a start. Thanks!
bergs
117
new jersey
Mar 11, 2004
  • Mar 11, 2004
i havent cahnged mine on the 02 yet, but it is right behing the rear bumper cover. when i changed them on my 5.0's i didnt use any tools or shut off the gas or whatever. its held on with 2 plastic clips that just pop off and a minimal ammount of gas leaks out, nothing to be worried about. you dont even need to jack up the car to change it.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 11, 2004
  • Mar 11, 2004
they got rid of the plastic clip things on the 96+ stangs
XTONKAX
619
UT
Mar 11, 2004
  • Mar 11, 2004
Actually, there are some plastic clips. However, they're just there as a backup in case the spring lock doesn't work. At least, it is this way on my 2000.
merc123
420
North GA
Mar 11, 2004
  • Mar 11, 2004
Another trick you can do is there should be a fuse you can pull for the fuel pump. Pull that then start/run the car. The motor will use the fuel in the lines/filter and have less spillage. Me, I just got tired of messing with it so I just pull the filter off my Cougar without doing that and let it spill.
GDawg
1,469
Nevada
Mar 11, 2004
  • Mar 11, 2004
I'm replacing my fuel filter and PCV valve this weekend.
Just wanted to let you know that when I asked my local Ford parts dealer the price for these items they wanted $22.46 (fuel filter) and $12.50 (PCV valve). I was able to buy the exact same ones from Mustangs Unlimited for $11.95 and $6.95 respectively. And with the shipping added, the whole thing was still $11.00 cheaper than buying from Ford. Shipping took 3 days to my door from time of order.
Mustangs Unlimited Fuel Filter
SatinSilverStan
48
Tampa, fl
Mar 11, 2004
  • Mar 11, 2004
At what mileage should the fuel filter be changed ?
jeff1414
447
Sacramento
Mar 11, 2004
#10
  • Mar 11, 2004
  • #10
I think it is every 30,000. It was hard to pull mine off i kind of and to pull and twist.
jason1320
60
Bowie MD
Mar 11, 2004
#11
  • Mar 11, 2004
  • #11
SK
This is a walkthrough I posted on another site. Enjoy!
http://forums.mustangworks.com/showthread.php?s=&threadid=41610&highlight=fuel+filter
SPKMustang
87
Amherst, NY
Mar 28, 2004
#12
  • Mar 28, 2004
  • #12
Ok well I tried to remove the fuel filter last ngiht with absolutly no luck. I got that tool you mentioned in that thread but in my noobish ways, how the hell exactly is it used???
Do you need to find the right sized whole and stick it in the larger side of the tapered piece of fiel line?
XTONKAX
619
UT
Mar 28, 2004
#13
  • Mar 28, 2004
  • #13
Yes. This releases the springlock and you should just be able to pull the two pieces apart.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
D
Is this a fuel filter?
  • Dutch74
  • Oct 2, 2025
1974 - 1978 Mustang II Talk & Tech Oct 21, 2025
welder4956
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
