Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • Thread starter Thread starter ChickenDeluxe
  • Start date Start date Thursday at 10:49 AM
C
ChickenDeluxe
Cloverly, MD
  • Thursday at 10:49 AM
1989 GT, Manual, mostly Stock.
Newer Tank and Sender
Fuel Gauge worked fine before.....
* Removing all Stereo, Interior, Dropped Column to refresh cluster, fix constant crank , bad Temp Gauge, and strip interior for rehab.
I'm thinking Ive missed a ground ?
Does cluster have a ground strap that affects Slosh Module/Gauge>?
Status:
Dash back in, but not all buttoned up.
Column is dropped/loose. Also tried tightening.
Changed Temp Gauge that was dead. Now Working
Had Dash light issue so replaced Circuit Board.
I've tried 3 Clusters, (2) 4 cyl ones,
All Gas gauge pegs past Full.
In restored 140 Cluster (I now have Dash light and Temp).
I've tried all 3 Slosh Modules with the new Circuit Board,
Same. over Full Condition .
I checked tank leads and re-grounded by sanding at taillight inner panel.
I suspect I may have left off a dash cluster ground?
Thoughts? What am I missing?
Thanks in Advance!!!!!!!!!!!!!!!
This is the last thing so I can start buttoning up interior!
AeroCoupe
6,051
4,160
183
Claremore, OK
Thursday at 6:23 PM
  • Thursday at 6:23 PM
Did you check the ohm range of the sending unit before you installed it? For our cars it should read 16 ohms empty and 158 ohms full.
C
ChickenDeluxe
Cloverly, MD
Thursday at 8:13 PM
  • Thursday at 8:13 PM
Found yellow/wht wire in Kick Panel Connector.
Disconnected and Grounded.
Gauge moved toward empty and stayed. there.
Reconnected that Plug, then found Connector under Rear Bumper and tested at Chassis Connector, Gauge did same.
Ohm'd Sender and have open Circuit.
Guess the tank coms down again!
Thanks for Looking or maybe this helps you
On with Dash Assembly with replaced Circuit Board, Temp Gauge and working Dash Lights!
Cheers!
Reactions: AeroCoupe
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
L
Fuel gauge and temp gauge
  • Logan1722
  • Jan 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 19, 2025
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 12:57 AM
2000ElectricGreen
