1989 GT, Manual, mostly Stock.
Newer Tank and Sender
Fuel Gauge worked fine before.....
* Removing all Stereo, Interior, Dropped Column to refresh cluster, fix constant crank , bad Temp Gauge, and strip interior for rehab.
I'm thinking Ive missed a ground ?
Does cluster have a ground strap that affects Slosh Module/Gauge>?
Status:
Dash back in, but not all buttoned up.
Column is dropped/loose. Also tried tightening.
Changed Temp Gauge that was dead. Now Working
Had Dash light issue so replaced Circuit Board.
I've tried 3 Clusters, (2) 4 cyl ones,
All Gas gauge pegs past Full.
In restored 140 Cluster (I now have Dash light and Temp).
I've tried all 3 Slosh Modules with the new Circuit Board,
Same. over Full Condition .
I checked tank leads and re-grounded by sanding at taillight inner panel.
I suspect I may have left off a dash cluster ground?
Thoughts? What am I missing?
Thanks in Advance!!!!!!!!!!!!!!!
This is the last thing so I can start buttoning up interior!
Status:
