fuel injected 351?
  • Thread starter Thread starter blue87lx
  • Start date Start date Aug 3, 2005
blue87lx
175
  • Aug 3, 2005
can i put a fuel injected windsor in my car or carb it
blue87lx
175
  • Aug 3, 2005
and for injected can i use the 302 computer since the firing order is the same
BaXTeR3221
917
Orange County, NY
Aug 3, 2005
  • Aug 3, 2005
I'm about the buy a car with a fuel injected 351. So it will work.
wildstanggt
186
Omaha, NE
Aug 3, 2005
  • Aug 3, 2005
Several people on here have EFI 351 based motors. I would recommend getting a PMS or some kind of piggyback or stand alone system. You will get a better tune equaling more power and fuel efficiency. Good luck
M
macx
228
SE Missouri near Cape Girardeau
Aug 4, 2005
  • Aug 4, 2005
See my combo in my sig.
I happened to find a used Ford mass air meter
that was calibrated to work with 30 lb inj's on
a 302 w/stock EEC-IV ecu.
Although it runs pretty good, I'm going to have
it dyno tuned to correct things like the load vs
timing & fuel tables, get the mixture right, etc.
I looked into getting a Tweecer or similar tuning
tool as I'm working on installing an electronically
controlled 4R70W and hoped I could use such a
thing to tune both the engine & trans. After doing
a bunch of reading, and finding that those tuning
devices take a LOT of learning/work/trial & error,
plus costing at least what a good dyno tune does
to start with, I decided not to commit the time/
effort/$ to go that route as I'm not changing my
combo or having to tune it weekly for the strip
etc. Besides, a good experienced dyno tuner
will undoubtedly be able to do a better, and safer,
tune that I could even with lots of working with it.
I'm using a stock A9P ecu.
Although efi is a bit more complicated, and
more costly, I feel it's definitely worth it when
you take into consideration the driveability,
low/mid range torque, smooth running,
fuel economy, and with the right intake
equal power. Good street 351 efi intakes are
the Edelbrock 351 lower with a high perf
Performer upper (not the baseline 302 Perf
upper), or especially the Trick Flow 351 efi
intake.
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Car bucks
  • 91stangman
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2026
Mindseye007
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
For Sale Holley 12-886 Fuel pressure regulator (New)
  • fasterthangas
  • Nov 30, 2025
  • Other Classifieds
Other Classifieds Aug 14, 2026
fasterthangas
F
