  • SVT Tech Forum
fuel injectors
  • Thread starter Thread starter COBRA_Miami_OH
  • Start date Start date Jan 24, 2004
C
COBRA_Miami_OH
  • Jan 24, 2004
first i was wondering what size are the stock fuel injectors on a 1996 cobra. Secondly should i upgrade to bigger ones. I have the timing adjusted, cold air intake, underdrive pullies, upgraded spark plugs and wires, long tube headers, h-pipe, diablo chip (not yet burned), and a 95mm mass air flow sensor. that is as far as engine upgrades go.
Tat98Cobra
681
  • Jan 24, 2004
Stock is 24lb injectors.
You dont need to upgrade them with your mods. You're not even close to maxing them - you can check yourself by hooking up a scanner during a wot run and check the injector's duty cycle status
peace
sinisterblack98
Sometimes I just lay on my garage floor and look u
967
Motor City, MI
Jan 24, 2004
  • Jan 24, 2004
Ditto...Not yet.
The chip can handle the pulse width or adjust the fuel pressure if needed, (or do you need an adjustable regulator on '96s?).
Either way, any good tuner will use a wideband O2 sensor to adjust the A/F ratio.
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Monday at 1:50 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 4:26 PM
DadLife0724
  • dan50
  • Jul 18, 2026
dan50
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • SVT Tech Forum
