86mustang5.oh said:
can i just plug my car in at auto zone ?
Here, I did the search for you... I copied this from one of JRichkers other posts. This will help you out a great deal!
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See
http://www.troublecodes.net/Ford/
OR
See
http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
For those who are intimidated by all the wires & connections, see
http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see
http://www.midwayautosupply.com/det...iption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35
