Ok, I still have unresolved drivability issues with my stang.
I have had a fuel smell ever since Ive bought this car. It reaks of gasoline. The car started shutting down while driving it. I thought I may have had spark issues so I replaced wires, plugs, cap/rotor, coil and tfi. That offered a mild and only temporary improvement. I couldnt start the car for a few days - until I tapped the stock fuel regulator with a hammer handle.
I set my TPS sensor to .976 volts.
I replaced the regulator and now its back to no more than 3k rpms under load. I dont need anymore because I tend to drive rather relaxed - I WANT IT BACK!
I bought a gauge that taps into the fuel line through the shrader valve. When I removed the shrader there was ****ing red permetex on the threads! WHAT KIND OF STUPID HICK WOULD DO THAT? So, I put the gauge in and set the fuel pressure to 39 psi with the vacuum tube plugged but off the FPR. I checked timing at 10 btdc.
All of these things to no avail.
What in the world should I do? What would cause such a strong gasoline smell without leaving a piss trail of gas?
Up next Im going to replace the injectors with an excellent set I have in hopes that the injectors have broken or rotted O rings.
Next it will be the fuel pump.
