Fuel level gauge problems
  • Thread starter Thread starter 68stang351
  • Start date Start date Oct 30, 2006
68stang351
850
9
39
Savoy TX
Oct 30, 2006
  • Oct 30, 2006
I did a search first, but that didn't help. Ever since we've had the car (3yrs) the fuel level gauge is stuck on empty, all the time. A few months ago, the fuel pump went out, so I replaced the complete assembly (pump and sending unit). It still reads empty. Any ideas? BTW, its the 90GT in my sig.
Thanks in advance
z2o_what
309
princeton, WV
Oct 30, 2006
  • Oct 30, 2006
by "sending unit" do you mean the fuel pump housing or the float assembly, because they are in seperate locations on mustangs.
if you changed them bolth you may want to try another guage cluster,
do the rest of the factory guages work?
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 31, 2006
  • Oct 31, 2006
The sending unit is a variable resistor that reads approximately 25 ohms for empty. If the gauge is always reading empty then either the gauge is stuck or it is always seeing 25 ohms. You could try connecting different resistors to the wiring to raise the level if the gauge does not respond to this then the gauge is bad.
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
