Fuel line questions
  • Thread starter Thread starter shootme5150
  • Start date Start date Oct 31, 2008
shootme5150
84
Denver
Oct 31, 2008
  • Oct 31, 2008
I'm pulling my engine and it looks like the last thing holding on are the fuel lines. Two questions:
1) Do I have to release the fuel pressure? If so, how would I go about doing that? My manual only talks of running the car with the inertia switch disconnected, but I'm not exactly in position to start it. I believe I found the schrader valve, but I have no idea what to do with it. I thought there would be a little 'pin' inside of it like a tire, but I can't feel anything.
2) How the %&$* do I get the fuel lines off? I've got a tool that looks kinda like this, but I can't seem to push or pull the connector. Will it not move if the lines are pressurized? Is this thing really THAT difficult to use (should I grab the little colored ones)?
Any help would be much appreciated.
TIA
ej95cobra
82
Southeastern PA
Oct 31, 2008
  • Oct 31, 2008
Yes you should release the pressure in the system. The schraeder valve is on the fuel rail and you should be able to see the pin (like the tire valves). Since you can't start the car, you'll get some gas on you. Another place to release pressue would be disconnecting the fuel filter. Again you'll get gas all over but usually it's not too much (I know, I've accidently done this on a pressurized system before).
The tool you have will work so long as the end sizes are appropriate for the fuel line connectors and fit inside the larger connection, though I'm used to having several different sizes, each in an individual circular tool. I have found that inserting the tool into the connection, holding the line that the tool is on, then pushing the two lines toward each other before pulling apart works best for me.
Good luck,
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
