Fuel Lines
When I changed my fuel filter, I couldn't believe how flimsy the little white plastic clip is that holds the fuel line to the filter. I'm like, "That doesn't seem like it's doing anything at all and that doesn't leak."
Thanks guys, especially @Spaz for the photos.
I was going to do that but after visiting a local shop, we were able to settle on the idea of cutting the soft line off and flaring the steel lines. Then using fittings go straight to the russell lines.
If those aren't long enough I also got the equipment to run fuel line and fittings rated to 300psi....should do the job. I'll post images when finished.
Reactions: Spaz
