Fuel Preasure question
  • Thread starter Thread starter Morales
  • Start date Start date Dec 20, 2005
M
Morales
136
Miami, FL
Dec 20, 2005
  • Dec 20, 2005
Ok, im installing the following on my car tomorrow
Trickflow Trackheat kit
190lph fuel pump
24# injectors
70mm TB and a larger MAF for the injectors
what should i set my Fuel Preassure at?
is 40 correct? or is 40 ideal for that setup with stock injectors and maf?
Daniel50
716
Discovery Bay, CA
Dec 20, 2005
  • Dec 20, 2005
tell you the truth whatever you set it at the computer will pretty much compensate for it and put it back to stocl with a afpr
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Dec 20, 2005
  • Dec 20, 2005
38 is stock, 40 should be fine.
Black1987Stang
1,422
Jersey Shore
Dec 21, 2005
  • Dec 21, 2005
Yea the computer will adjust to it by adjusting the injector pulsewidth. Isnt adjusting the fuel pressure mostly for WOT,(thats why u set it without vacuum...since theres no vacuum at WOT).? Since the computer doesnt read off any sensors during WOT. the different pressure would add or lessen the fuel at WOT wouldnt it?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 21, 2005
  • Dec 21, 2005
At WOT, the air/fuel ratio is a function of fuel pressure, RPM, airflow through the MAF (mass air cars only) and the TPS. The O2 sensors don't have any control input into the computer's program at WOT.
Therefore you can use the SOP meter...
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have you buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in. Watch for the wind speed and direction, it can have a definite impact on your test results. Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
  • dan50
  • Jul 18, 2026
dan50
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
