Fuel press Problem
  • Thread starter Thread starter ninety15.0
  • Start date Start date May 9, 2004
ninety15.0
1,336
  • May 9, 2004
I think my fuel pump is on its way out and isnt pumping as much as it should especially at high rpms. So i bought a fuel pres. guage from jegs and i got the guage and it doesnt have any fittings to go with it?!? The fitting on the back of the guage is a 1/8 NPT male fitting. I cant think of or find any fitting to just go right into the schrader valve on the fuel rail. Do u need to remove the schrader valve and plug the 1/8 NPT female reducer fitting right into the fuel rail or what? IM very confused and i have called jegs and summit and they have absolutely no idea what the hell to do. Any suggestions would be awesome. thanks in advance. -Nick
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 10, 2004
  • May 10, 2004
Carefully remove the schrader valve from the fuel rail, then install the adapter. The gauges come in two types: one mounts directly on the adapter on the rail. The other type uses a fex hose to connect the gauge to the adapter and allows you to mount the gauge just about any place you have room.
You can buy the Autometer Stainless Steel braided hose for like $60. Or a local shop that makes hydraulic hose assemblies can make it for you at a cheaper price. Ordinary low pressure hydraulic hose can be used in place of the Stainless Steel braided hose, the Stainless Steel braided hose just looks nice. I got mine for $4 at a place that sells industrial and military surplus parts of all kinds. The Stainless Steel braided hose goes for about $3.60 a foot and the fittings are probably about $5-$8 each. You can make your own and save some $$$, the shops may have a setup or labor charge to fabricate the hose assembly.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
  • dan50
  • Jul 18, 2026
dan50
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
