fuel pressure and dump codes
noslow1986
274
oswego Il
i check the fuel it idles at 35 psi .when i put more throttle and hold it at 2000 rpms the pressure goes ups to 40 psi then drops back to 35psi but i still have the throttle at 2000 shouldnt it stay at 40 why a drop in pressure
Once you level out the pedal, the FPR starts passing more fuel (than it was when you were opening the throttle, thus decreasing manifold-vac per time).
It sounds about right IMHO.
The engine makes vacuum anytime it is running. The FPR is connected to the intake manifold to read the vacuum. For every 2 inches of vacuum that is in the intake manifold, the fuel pressure is decreased by 1 PSI.
That means at idle with 20 inches of vacuum you will see 28-30 PSI fuel pressure. At 2000 RPM cruse with 15 inches of vacuum you will see 32-34 PSI fuel pressure.
The same thing holds true for pressure inside the intake manifold. For each 1 PSI of boost, the FPR increases the fuel pressure by 1 PSI, as long as the fuel pump is up to the job.
The increase with pressure and decrease with vacuum insures that the fuel injectors always deliver the same volume of fuel at 100% duty cycle. This allows the computer to vary the injector pulse width to richen or lean out the air fuel ratio.
i got a canister purge code i deleted it the unit thou should i be worried about that. and i have a 1 inch spacer inbetween upper and lower intake and in the back its wet. i pulled my upper intake off and could smell fuel is this normal. i think im going to have someone look at it cause im tired off screwing with it
